10 years agoCyclone V HPS UART, can't rx data
I can send RS232 data via HPS UART1 but unable to read data. The scope shows RS232 data on RX pin but test code can’t read any data from /dev/ttyS1 and nothing when I ‘cat /dev/ttyS1’ I can thi...
9 years agoHi,
I am encountering the same issue. I've tried to do the following "declaring '1' on input pins CTS, DSR, DCD, RI" hps_ips_hps_0# ( .F2S_Width (2), .S2F_Width (2) ) hps_0 ( .h2f_mpu_eventi (), // h2f_mpu_events.eventi .h2f_mpu_evento (), // .evento .h2f_mpu_standbywfe (), // .standbywfe .h2f_mpu_standbywfi (), // .standbywfi .uart1_cts (1'b1), // uart1.cts.uart1_dsr (1'b1), // .dsr
.uart1_dcd (1'b1), // .dcd
.uart1_ri (1'b1), // .ri
.uart1_dtr (hps_0_uart1_dtr), // .dtr .uart1_rts (hps_0_uart1_rts), // .rts .uart1_out1_n (hps_0_uart1_out1_n), // .out1_n .uart1_out2_n (hps_0_uart1_out2_n), // .out2_n .uart1_rxd (hps_0_uart1_rxd), // .rxd .uart1_txd (hps_0_uart1_txd), // .txd But it changes nothing. I use original u-boot and kernel 4.8. And I am wondering if the following "generating and updating preloader/uboot." maybe matters in this case. If it does what should be changed at u-boot before generation it? Btw, I got something like this while running minicom on /dev/ttyS1 (with and without pins routing to FPGA enabled) [ 23.302445] ttyS1 - failed to request DMA What could go wrong? Thanks in advance
