11 years agoCyclone V GX using all 6 transceivers in both directions
I want to use all 6 transceivers for Gb Ethernet communication but I'm having trouble with the IP and assigning a TX PLL that is not from one of the channels as these are all used for RX. Is it...
Click_Er
7 years agoI'm working on something similar.
Cyclone V GX Transceiver setup
I'm putting together a 2 channel transceiver design on a cyclone V GX device. This device has 3 channels. I want to use channel 1 and 3 since the custom board has already been designed and wired to these channels. All 3 channels are on the same bank in this device. Can I use IP wizard and generate a channel with its PLL. After that is done, can I simply instantiate the generated IP second time and wire it up to the dedicated pins? Will my approach work? Or do I need to create a 2 channel IP?
