11 years agoCyclone V GX using all 6 transceivers in both directions
I want to use all 6 transceivers for Gb Ethernet communication but I'm having trouble with the IP and assigning a TX PLL that is not from one of the channels as these are all used for RX. Is it...
11 years agoIt is possible to use fPLL to clock all the 6 transmitters. You can try to test out a test design and run through Fitter compilation.
