12 years agoCyclone V GX to Cyclone V GX interfacing.
Hi there.... My name is Jitendra and I'm design board using Cyclone V GX .And My question is , How to interface the two Cyclone V GX FPGA? As reason for interfacing is to use one FPGA as for Pr...
12 years agoHi Jitendra:
From FPGA to FPGA there are the sky is truly the limit on how you can interface two FPGA's. The main driving factor is your requirements, and how much data you need to push between the two devices. You said you are using one as a Processor, and the second as a device. Are you using the SOC's varients? It may be easiest to use PCIe interfaces in that case. Pete
