11 years agoCyclone V GX Starter Kit - Audio Codec
Hello, I have recently purchased a Cyclone V GX Starter Kit (https://c5g.terasic.com) which includes an onboard Audio Codec chip (SSM2603). I am fairly new to FPGA's, used them a bit in school...
11 years agoI believe the board is bad. We have two of the boards here at work. One does NOT produce audio out when using the default configuration. The second card does produce the 1Khz signal as the manual says.
