jsam0502
6 years agoCyclone V GX EPCQ
I was wondering if it would be possible to reflash an EPCQ through a UART connection? And if so, what are the IP cores needed? I'm also trying to lean away from using a soft processor. So I'll ...
YuanLi_S_Intel
6 years agoHi John,
Yes you can, with the aid of serial flash IP. You need to generated RPD file in big endian format, then program the EPCQ with RPD file using serial flash IP.
You may take a look at serial flash user guide for more information about it:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-gen-sfi.pdf
Thank You.
Bruce
