12 years agoCyclone V GT dev kit - BTS doesn't work
Hello, I have a Cyclone V GT dev kit ( DK-DEV-5CGTD9N ). It is connected to Ethernet, USB (on-board blaster) and external power. The PCIe is not connected. The card works, I can view the Bo...
11 years agoHi tshauli,
I believe you can try look into the last issue which is the conf_done does not goes high. You can try download the reference manual and check if all the switches are in their factory reset settings. The other thing would be to use the QII to actually check if you can actually detect the FPGA in the programmer. then as bfkstimchan mentioned, you can also tried a simple design, perhaps a simple RTL just to make sure the conf_done can go high.
