MKlee2
7 years agoCyclone V Gbx Transceivers - can't fit more than 4, should be able to use 6? Error (14566): The Fitter cannot place 5 periphery component(s) due to conflicts with existing constraints (5 Channel PLL(s)).
Device: 5CSXFC6C6U23C7 Problem: I'm trying to use a transceiver with 5 channels (2.5Gbps preset with more channels), but the fitter throws me an error about occupied pll locations. From my unders...
CheepinC_altera
7 years agoHi Matthias,
As I understand it, you observe some Fitter error during your compilation with CV XCVR design. As I check the CV part that you are using, there are total of 6 XCVR channels. By default, you should be able to implement maximum of 5 duplex XCVR with one channel reserved for CMU PLL. Would you mind to share a simple test design with Native PHY which could replicate the error observation so that I could further look into it?
Thank you.
- MKlee27 years ago
I played a bit around with my pin planning and it seems to work if I leave AB2/1 and Y2/1 free and use F2/1 D2/1 instead.
Could you please tell me why I need to leave out this specific(?) pins? I also tried leaving out other pins on the same bank and use AB2... again,
but this would result in an error again.
- MKlee27 years ago
Thank you for your answer, attached is a simple test design.
I believe it might be related to my pin planning/placing, maybe you point out what went wrong.
