12 years agoCyclone V fitter cannot place fractional PLL
Hi All! Right now I'm trying to compile the simple design to check if pin assignment is correct before I start to route the PCB. In our project we use 8 ADCs (output interface of each ADC is 9x...
12 years agoWhen the fitter fails, when you run it without any pin assignments, what are the errors it fails with? Do you still have the problem? If not, do post the solution...
Cheers, Alex
