12 years agoCyclone V fitter cannot place fractional PLL
Hi All! Right now I'm trying to compile the simple design to check if pin assignment is correct before I start to route the PCB. In our project we use 8 ADCs (output interface of each ADC is 9x...
12 years agoHave you tried to cascade two fPLL?. Set the output of the first one as the input of the second one, which should be the transceiver's PLL. I found the same problem using the cycloneV development board and I overcome the problem doing that.
Luck.
