12 years agoCyclone V fitter cannot place fractional PLL
Hi All! Right now I'm trying to compile the simple design to check if pin assignment is correct before I start to route the PCB. In our project we use 8 ADCs (output interface of each ADC is 9x...
12 years ago --- Quote Start --- Have you tried compiling the project without any pin assignments? Based on what you've presented I would anticipate a solution being available. However, it may be that the assignments you've already made are preventing Quartus from finding a fit for your design. Regards, Alex --- Quote End --- Yes, I tried to compile the design with no pins assigned and the fitter also wasn't able to fit the design into the FPGA. Regards, K
