9 years agoCyclone V DMA/DRAM Issues
5CGTFD9E5F35C7
Cyclone V GT Development Board I am trouble interfacing with the on-board DRAM using the Avalon bus. I have attached the file used for testing. When trying to access DRAM the signal waitrequest_n(indicating the memory controller is busy) never goes high, even on initialization. I have verified that all pin assignments are correct and the memory is configured correctly in QSYS. I have tried asserting a write even though the bus is busy, as recommended by the Altera documentation. However, that did not work and the waitrequest_n signal did not go high. Another user has tested the board before me and verified the functionality of DRAM. I have also attempted to use the board test system and that does not give me results. I programmed the board using Quartus 14.1 manually and used the provided Signal Tap file. The signal tap gave me 'waiting for clock status' indicating the clock was not toggling. I changed the default clock to one of the programmable oscillators. That also did not work. So my question is am I missing something major or is it likely that the board is malfunctioning.No RepliesBe the first to reply
