11 years agoCyclone V DDR3L & 1.35V I/O
My platform is Cyclone V SX series FPGA with DDR3L for HPS and for FPGA. Problem: DDR3L is 1.35V. I need to use SSTL-135 for the FPGA banks with DDR3. Also I want to use free pins of the same ba...
11 years agoIf I use SSTL-135, then I have error described in https://www.altera.com/support/support-resources/knowledge-base/solutions/rd01292013_881.html. This link also has workaround/fix for this problem.
Using this fix everything OK. But now one more question about SSTL-135. My signals are very slow, this means I don't need to terminate them at the both sides. So if I don't use input parallel termination will I have voltage range of a signal from 0 to 1.35V (like LVCMOS)? Thanks.
