11 years agoCyclone V DDR3L & 1.35V I/O
My platform is Cyclone V SX series FPGA with DDR3L for HPS and for FPGA. Problem: DDR3L is 1.35V. I need to use SSTL-135 for the FPGA banks with DDR3. Also I want to use free pins of the same ba...
11 years agoIf the actual voltage supply in hardware is lower than the required, you should expect that the IO performance might be out from the specs.
