12 years agoCyclone V Core overpower effects
Hi, I plan to use a Cyclone V FPGA in combination with a LPDDR2 RAM from Micron. The Cyclone V FPGA needs 1.07V .. 1.13V for the core, and 1.14V .. 1.26V for the 1.2V-IO-Pins. The Micron...
12 years ago --- Quote Start --- Hi, (a) What effects do I have to consider if I power the FPGA core with 1.2V instead of 1.1V to save one voltage regulator? (BTW: 1.2V is far away from the absolute maximum rating of 1.43V...) --- Quote End --- Could you use a diode or two to get the FPGA core IO down nearer to 1.1V? You'd need to work out the power rating for your anticipated I_core but it might be cheaper than a regulator. Nial
