Cyclone V Configuration
Hi SK,
If you are configuring using AS x4 mode, i would suggest you generate JIC instead of POF. POF is meant for PS / FPP mode.
Meanwhile for configuration device selection, you just select EPCQ64 will do. Select the configuration device that you are using.
Thank You
I created jic and tested. But the jic file size is also 32769KB. EPCQ64 will not support this file size.
So I had to use MT25QL256 Flash device. I have enabled the "Generate compressed bitstream" option in the configuration settings.
But when I create auto rpd along with pof the file size is 12MB.
I have to program the FPGA image and NIOS application image to the flash via jtag.
Please help me to understand how this can be done. I would also like to know the difference between rbf and rpd files.
