SNard3
6 years agoCyclone V Configuration
Hi, we need to replace EPCQ256, with active serial configuration mode, programmed through jtag and jic files. In quartus conversion programming file tool I've found several memories and try to use...
ShafiqY_Intel
6 years agoHi SNard3,
May I know which Quartus Version you are using?
For MX25L128 device, we starting support this device from Quartus version 18.1 onwards.
If you want to find the replace for EPCQ device, you may follow the link Intel Supported 3rd party device below. The listed devices were tested by Intel.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/support-centers/configuration-support.html
(go to left hand side option Intel Supported Configuration Devices --> Intel supported Third Part Configuration Devices.)
I hope this will help you.
