9 years agoCyclone V Configuration Devices
I've got a Terasic Cyclone V GX development board. I removed the EPCQ256 configuration device and am testing two other alternatives (Macronix MX25L257 and Cypress S25FL128). I created a simple proj...
8 years agoHi corestar,
I have MSEL at 10010, but 10011 should be fine for ASx1, it's the same configuration but with a longer POR delay. CLKUSR is not connected. I don't think you need a Serial Flash Loader core if you don't specifically want to make your own flash loader. In Conversion Setup I have the start address of SOF data set to 0x0, and "Disable EPCS/EPCQ ID check" is enabled in the Advanced Options. Otherwise the conversion setup is the same as yours.
