9 years agoCyclone V Configuration Devices
I've got a Terasic Cyclone V GX development board. I removed the EPCQ256 configuration device and am testing two other alternatives (Macronix MX25L257 and Cypress S25FL128). I created a simple proj...
8 years agoilkkak,
We got our board with the W25Q128JV and I'm having trouble. Could you provide more details on how you got it working? I'm trying to follow AP370 but it is not very clear. We set MSEL to 10011 and the schematic is as per Fig 7-9 in the Cyclone V datasheet for "Single device As x1 Mode Configuration". CLKUSR is not connected. I created a JIC file as per AN370, but after a while the config fails with an error that it can't recognize the silicon ID. Note, I can program the FPGA itself fine with the sof used to create the jic. Do I have to create the Serial Flash Loader core in the design? AN370 seems to imply it will use a factory default. https://alteraforum.com/forum/attachment.php?attachmentid=14755&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14756&stc=1 https://alteraforum.com/forum/attachment.php?attachmentid=14757&stc=1
