9 years agoCyclone V Configuration Devices
I've got a Terasic Cyclone V GX development board. I removed the EPCQ256 configuration device and am testing two other alternatives (Macronix MX25L257 and Cypress S25FL128). I created a simple proj...
8 years ago --- Quote Start --- Yes, with the W25Q128JV it boots and works fine in all respects as far as I can tell with a day's testing. I'm using ASx1 too. --- Quote End --- Thanks for the info. One less thing to worry about. Hopefully, Intel will simplify this in the future, but this works for now. Seems like their own 3D XPoint memory would be an ideal solution to replace their SRAM based FPGA with something that combines the best of FLASH and SRAM based chips. I'm not knowledgeable enough to know for sure of course, but it seems like it is denser, cheaper and lower power than SRAM and would eliminate the need for external FLASH altogether.
