Seadog
5 years agoCyclone V build fails due to missing DDR3 files
I am trying to build a Cyclone V design (QPS 20.1.1 on Win10) and getting the following error messages:
Error (12006): Node instance "s0" instantiates undefined entity "ddr3_v20_s0". Ensure that re...
sstrell
5 years agoThe easiest thing to try first is to regenerate the IP. You can reopen the parameter editor for each instance and regenerate.
The fact that mm_interconnect is listed makes me think you are using Platform Designer. Are you? If so, make sure either the .qsys file or the .qip file generated by Platform Designer is added to the Quartus project.
