9 years ago
Cyclone V bidirectional half-duplex LVDS?
Dear All,
We are designing a board with a Cyclone V connected to another (already existing) board via a bidirectional half-duplex LVDS link. We would prefer to use only 2 pins of the FPGA to implement both the Rx and the Tx. I tried the following:
  • I defined an ALTIOBUF "As bidirectional buffer", and "Use differential mode". See attached file.
  • I used the IO_STANDARD "DIFFERENTIAL 2.5-V SSTL CLASS I".
  • I instanciate the ALTIOBUF in the natural way:
Ulvds : altiobuf_lvds port map
datain => Tx_data,
dataio => FPGA_PIN_P,
dataio_b => FPGA_PIN_N,
dataout => Rx_data,
oe => output_enable,
oe_b => output_enable
(By the way, the oe_b is the output enable for the complemented signal, or the complement of the output enable?)
It seems that Quartus can compile the design, and the Pin-Out File in the report contains
FPGA_PIN_P : U27 : bidir : Differential 2.5-V SSTL Class I : : 5B : N
FPGA_PIN_N : U28 : bidir : Differential 2.5-V SSTL Class I : : 5B : N
Is it correct? It seems contradictory to the documentation and other posts related to this question (or related to BLVDS).
To be complete: Cyclone V: 5CEBA9F31C8, Quartus Prime 16.1.0 Build 196 10/24/2016 SJ Lite Edition.
Thank you
    I understand that the Cyclone V BLVDS implementation with differential SSTL IO-standard uses the same termination resistors as the AN522 Cyclone III/IV implementation, 50 ohm near series termination and far differential 100 ohm termination at both bus ends. Optionally bias resistors.
    Does "emulated DIFFOUT capability" means that we need an "External resistor network"?
    See "Cyclone® V Device Family Pin Connection Guidelines - PCG-01014-2.5"
    Is it a good idea to put the external resistor network (for output) and use also the differential input?
    Thank you
    You *cannot* use the DIFFIO_TX pins on Cyclone V for differential input signals. These signals connect to the dedicated TX channels. The DIFFIO_RX pins can be used, for output signals, by virtue of their emulated DIFFOUT capability. So, for a bidirectional differential signal you must use a DIFFIO_RX pair.
    Cheers,
    Alex
    Thank you a_x_h_75!
    We are happy that it is correct. However, I am not sure to understand the AN522 "Implementing Bus LVDS Interface in Supported Altera
    Device Families", on page 6, there is a footnote "DIFFIO_TX pin does not support true LVDS differential receivers". Does it mean that for our purpose one should *not* use DIFFIO_TX pins, but DIFFIO_RX pins work well (can be transmit/receive/be tri-stated). Indeed Quartus selected some DIFFIO_RX pins. Nevertheless it seems that our goal is somehow similar to Bus-LVDS?
    Yes, this is correct. Another area where Cyclone V differs from previous families. This would not work with Cyclone IV. DIFFERENTIAL 2.5-V SSTL CLASS I cannot be tri-stated there. However, Cyclone IV supports Bus LVDS. Cyclone V doesn't.
    You seem to get "oe_b" for free - even if you don't want it. Tie it off low if you're happy using a single ended signal driving "oe".
    Cheers,
    Alex
