8 years agoCyclone V AS configuration using Micron MT25Q
I have a card with aCyclone V that is using Active Serial Configuration from a Micron N25Q(128Mbit) flash. Recently i have hadto switch flash to Micron MT25Q, due to the fact that N25Q is end-of-l...
Lukas187
4 years agoEven if this is an very old message:
I came across this, because I have exactly the same issue: Cyclone V soc with MT25Q
Traces are quite short (D0-D4: 16-20 mm; DCLK 18mm).
On some boards the AS config fails. As soon as I touch the DCLK (when trying to measure where the issue may be) the configuration is successful.
I also assume a timing problem but cannot find any setup or hold timing issues.
How was this problem solved? I would be more than happy to get a hint.
Thank you very much
Lukas
