11 years agoCyclone V active serial configuration w/ EPCS128 failure.
Hi all, I have run in to an issue on my custom board that I can't seem to figure out. - The board has an active serial configuration setup. The EPCS128 is programmed by an external program...
11 years agoI am loading the EPCS with the .pof generated from quartus. I have tried having it generate it directly and using the conversion utility from the .sof. I did just try using the .rbf file reversing bits and still getting error. Do I need to reverse the .pof as well?
