11 years agoCyclone V active serial configuration w/ EPCS128 failure.
Hi all, I have run in to an issue on my custom board that I can't seem to figure out. - The board has an active serial configuration setup. The EPCS128 is programmed by an external program...
11 years agoHave you looked at the contents of an epcq programed from a .pof by quartos?
It might be that you aren't writing the data correctly. In particular are you remembering to bit-reverse the bytes from those in the .rbf file?
