11 years agoCyclone V active serial configuration w/ EPCS128 failure.
Hi all, I have run in to an issue on my custom board that I can't seem to figure out. - The board has an active serial configuration setup. The EPCS128 is programmed by an external program...
11 years agoI'm no expert on AS programming and what could cause the sequence to abort/restart, but I'd be looking at the contents of the EPCS128 as the possible source of the problem. Are you loading the .rbf file from Quartus into the EPCS128?
