Cyclone V (5CGTFD9) 4X PCIe Connections for Data Lines and RefClk
Hi @ToddW,
Are you referring to the Cyclone V GT dev kit?
https://www.intel.com/content/www/us/en/products/details/fpga/development-kits/cyclone/v-gt.html
According to Figure 1-5 in Cyclone V Device Handbook Volume 2: Transceivers (ug-cv_5v3-683586-670578), the PCIe Hard IP blocks are located across Ch 1 and Ch 2 of bank GXB_L0, and Ch 1 and Ch 2 of bank GXB_L2. This means the PCIe Hard IP block is located near the mentioned channels. It does not mean that the PCIe Hard IP cannot use channels such as 0 and 3.
Please connect the input reference clock to pin W11 (PCIE_REFCLK_P) and V10 (PCIE_REFCLK_N). Ensure that the DIP switches on the dev kit are set to default positions following Section 4.2: https://www.intel.com/content/www/us/en/docs/programmable/792833/current/factory-default-switch-and-jumper-settings.html
You may try the Cyclone V PCIe Gen 2.0 x4 design from the FPGA Design Store and refer to the QSF for the pin assignments of PCIe signals. It works for the Cyclone® V GT FPGA Development Kit DK-DEV-5CGTD9N to bring up the Gen2 x4 configuration:
Ven
