XinYuSu
4 years agoCyclone V 5CEFA9U19C8 AS Configuration with Macronix mx25l12833fm2i-10g
I'm currently trying to get a Cyclone V 5CEFA9U19C8 FPGA to boot via Active Serial using the MX25L12833FM2I-10G chip. Based on the datasheet, this chip is the 8-Pin SOP version of the MX25L128...
YuanLi_S_Intel
4 years agoYes, you use nStatus as an indicator for that as it is pulled low when configuration error happens.
- XinYuSu4 years ago
I tried checking the n_status signal and it never seems to go low. Once a configuration error occurs, is it held low, or does it come back up? Would imagine if the latter happens, it would still trigger a falling edge on the logic analyzer, but I do not see anything
