XinYuSu
4 years agoCyclone V 5CEFA9U19C8 AS Configuration with Macronix mx25l12833fm2i-10g
I'm currently trying to get a Cyclone V 5CEFA9U19C8 FPGA to boot via Active Serial using the MX25L12833FM2I-10G chip. Based on the datasheet, this chip is the 8-Pin SOP version of the MX25L128...
YuanLi_S_Intel
4 years agoHi, apologize that we have tested only MX25L12833FMI-10G. Meanwhile for MX25L12833FM2I-10G, it could be the issue. I would suggest reading out the signal from all the data pin and see where it stuck at.
For non-supported flash, I would suggest to create the programming file using our generic flash programmer. You may refer to link below:
- XinYuSu4 years ago
Will do, thank you. Is there anything I should be looking for to determine where it gets stuck? My immediate thought is to run a trigger on nStatus to see when it goes LOW and see what commands are being run prior.
