8 years agoCyclone V 12bit LVDS deserialisation.
Hi all, I'm interested in using the Cylcone V for a project involving an image sensor with 4 DDR LVDS channels each 12 bit encoded. I noticed, in the LVDS RX IP, 10 bit word lengths is the maxi...
8 years agoI'm using x6 SERDES and combining 2x6Bit to 12 Bit output at half slowclock rate. 12-Bit ADC with LVDS output at 480 MHz LVDS/40 MHz output data rate.
Used code as is
LVDSCLK : altera_pll
GENERIC MAP
operation_mode => "lvds",
reference_clock_frequency => "40.0 MHz",
number_of_clocks => 4,
output_clock_frequency0 => "480.0 MHz",
phase_shift0 => "1041 ps",
duty_cycle0 => 50,
output_clock_frequency1 => "80.0 MHz",
phase_shift1 => "-5208 ps",
duty_cycle1 => 50,
output_clock_frequency2 => "80.0 MHz",
phase_shift2 => "4167 ps",
duty_cycle2 => 17,
output_clock_frequency3 => "40.0 MHz",
phase_shift3 => "7292 ps",
duty_cycle3 => 50
PORT MAP
rst => reset,
refclk => AD9222_FCO,
outclk(0) => fastclock, -- 180° 1041 ps
outclk(1) => slowclock, -- 210° -5208 ps
outclk(2) => enaclock, -- 120° 4167 ps
outclk(3) => outclock,
locked => rx_locked
chan:
FOR I IN 0 TO N_AD_CHAN - 1 GENERATE
ALTLVDS_RX_component : ALTLVDS_RX
GENERIC MAP (
buffer_implementation => "RAM",
cds_mode => "UNUSED",
common_rx_tx_pll => "ON",
data_align_rollover => 4,
data_rate => "480.0 Mbps",
deserialization_factor => 6,
dpa_initial_phase_value => 0,
dpll_lock_count => 0,
dpll_lock_window => 0,
enable_clock_pin_mode => "UNUSED",
enable_dpa_align_to_rising_edge_only => "OFF",
enable_dpa_calibration => "ON",
enable_dpa_fifo => "UNUSED",
enable_dpa_initial_phase_selection => "OFF",
enable_dpa_mode => "OFF",
enable_dpa_pll_calibration => "OFF",
enable_soft_cdr_mode => "OFF",
implement_in_les => "OFF",
inclock_boost => 0,
inclock_data_alignment => "EDGE_ALIGNED",
inclock_period => 25000,
inclock_phase_shift => 0,
input_data_rate => 480,
intended_device_family => "Cyclone V",
lose_lock_on_one_change => "UNUSED",
lpm_hint => "CBX_MODULE_PREFIX=lvds",
lpm_type => "altlvds_rx",
number_of_channels => 1,
outclock_resource => "AUTO",
pll_operation_mode => "NORMAL",
pll_self_reset_on_loss_lock => "ON",
port_rx_channel_data_align => "PORT_UNUSED",
port_rx_data_align => "PORT_UNUSED",
refclk_frequency => "40.000000 MHz",
registered_data_align_input => "UNUSED",
registered_output => "OFF",
reset_fifo_at_first_lock => "UNUSED",
rx_align_data_reg => "RISING_EDGE",
sim_dpa_is_negative_ppm_drift => "OFF",
sim_dpa_net_ppm_variation => 0,
sim_dpa_output_clock_phase_shift => 0,
use_coreclock_input => "OFF",
use_dpll_rawperror => "OFF",
use_external_pll => "ON",
use_no_phase_shift => "ON",
x_on_bitslip => "ON"
--clk_src_is_pll => "off"
PORT MAP (
rx_enable => enaclock,
rx_in => AD9222_D(I TO I),
rx_inclock => fastclock,
rx_out => rx_out(I)
PROCESS (slowclock, reset)
BEGIN
IF rising_edge(slowclock) THEN
reg1(I) <= rx_out(I);
reg2(I) <= reg1(I);
reg3(I) <= reg2(I);
END IF;
END PROCESS;
PROCESS (outclock, reset)
BEGIN
IF reset = '1' THEN
lvds_rx(I) <= (others => '0');
ELSIF rising_edge(outclock) THEN
lvds_rx(I) <= reg2(i) & reg1(i);
END IF;
END PROCESS;
