13 years agoCyclone V - Interrupt Handling
Hello, i would like to know, how I can use interrupts in conjunction with a Cyclone V. (Comparative Avalon) Do you probably have an example for me? I would like to trigger an interrupt using a b...
12 years agoYou might need to scroll the system panel to the right to see it. It'll be a column to the right of the HPS and all the other components in your system. You might also have interrupts filtered from the UI so if you click the filter button you can expose the interrupts (I normally just click the "all" filter so that I can see everything).
Last but not lease make sure the interrupt interface for the HPS is enabled in the HPS component, otherwise those interrupt lines will not be exposed in Qsys.
