TMayd
7 years agoCyclone V - Active Serial using MT25Q. Do you connect AS_DATA0 to the DQ0 on the chip?
Now that the Micron MT25Q are validated to work with active serial I was just wondering for the MT25QL128 chip if I route it similarly as I would have wired the EPCQ devices? I am just a bit overwhel...
Nooraini_Y_Intel
7 years agoHi TMayd,
You need to use Convert Programming File utilities in Quartus Prime v18.1 to generate the programming files (.jic/.pof) for MT25QL devices. You can refer to the attached screen shot.
Nooraini
