TMayd
7 years agoCyclone V - Active Serial using MT25Q. Do you connect AS_DATA0 to the DQ0 on the chip?
Now that the Micron MT25Q are validated to work with active serial I was just wondering for the MT25QL128 chip if I route it similarly as I would have wired the EPCQ devices? I am just a bit overwhel...
TMayd
7 years agoThank you, this is perfect. In my "Device and Pin Options" I would select active serial x4 but then it doesn't give me the option to choose my MT25Q configuration device? Do I just select auto? Do potentially have access to development kit for a Cyclone VE that could also share? Again thank you for your support.
