TMayd
7 years agoCyclone V - Active Serial using MT25Q. Do you connect AS_DATA0 to the DQ0 on the chip?
Now that the Micron MT25Q are validated to work with active serial I was just wondering for the MT25QL128 chip if I route it similarly as I would have wired the EPCQ devices? I am just a bit overwhel...
Nooraini_Y_Intel
7 years agoHi TMayd,
Yes, you are correct. The pin connection for MT25Q devices should be similar as with the EPCQ pin connection to the Cyclone V device. You can actually refer to the Stratix V development kit schematic on the connection since it is using NT25Q256 device for AS configuration.
Nooraini
