12 years agoCyclone PLL output clock pin assignment
Hi, I am using Cyclone IV E FPGA. There are four PLLs on the chip at four corners of the chip respectively. My first question, how many off-chip output clocks are there for each dedicated PLL? ...
12 years agoThanks Pete for your reply.
Still need your clarification to my question. Based on your reply can i suppose each PLL doesn't have more than one clock output? That means if i use PLL3_CLOCKOUTp pin as a single ended output clock i could not use PLL3_CLOCKOUTn as a second clock output from the same PLL3. Right? Yaoting
