11 years agoCyclone PLL frequency range
I’m currently working on project which uses Cyclone Family Part#EP1C20F400I7. Device has internal PLL and I’m using Altera’s megafunction “altpll” component to simulate logic. The device has been con...
11 years agoAs for the minimum frequency, you can check the Cycone datasheet. As I look at the doc, it seems like minimum is 15.625MHz which is some distance from your kHz requirement.
