Gauthier_Auvray
3 years agoCyclone IV GX ALTLVDS_RX
In a project we use ALTLVDS_RX (9 channels, de-serialization factor=6) in a Cyclone IV GX FPGA.
If my understanding is correct:
- SERDES is implemented in LE (with DDIO)
- DPA is not available fo...
AqidAyman_Altera
3 years agoHello Gauthier,
Thank you for reaching out Intel FPGA Community.
I would like to recommend you check on this Knowledge Base article published regarding the error. You can refer to this link:
Warning (176441): The I/O pin < pin name > cannot meet the... (intel.com)
There is also community discussion that was similar on the error seen by you. Refer here:
I hope it helps you a bit.
Aqid
