12 years agoCyclone IV (EP4CE15E22C7N): CONF_DONE pin failed to go high in device 1
Hello everyone I designed my first PCB with a Cyclone IV FPGA. Unfortunately, I can't configure the device. Here's the log: --- Quote Start --- Info (209060): Started Prog...
12 years ago --- Quote Start --- Ok, onto the next likely candidate. MSEL pins should be tied to VCCA or GND. You have tied one to VCCIO. Cheers, Dave --- Quote End --- Thank you for that, problem solved!
