12 years ago
Cyclone IV E Remote Update problem
I have one thing to check out.
I am recently use Altasmi_parallel & altremote_update for my Cyclone IV E for remote update. and use EPCS64, i have finish two project, one for Factory mode and the other is Application mode, and then combine the two .sof into a .pof file and then program into the EPCS64, and now i want to update the application file remote, i will erase the exist application in the EPCS64 and then write the new file. and my question is: what file do i need to send down? is it new .sof? or other file?
Does the EPCS remote update support other file? take a example.thanks!
stephua
    Do you implement the Remote Update? I meet the same problem, can you share the experience?
    Thanks!
    It sounds like you are trying to store two FPGA images in a single EPCS64. In which case you need to store the .sof file at each boot address.
