Langail's avatar
Langail
4 years ago
Cyclone IV E Problem with FLASH programming
it's first time I'm here and I have no experience with Intel's FPGA. I just got a project for DE0-Nano dev kit and I just received and processed a SPI communication with other MCU. But now there is a request to design custom board containing FPGA and my part with MCU. I have designed board for EP4CE22E22C6 (same FPGA just package is TQFP-144) with Cypress S25FL128S flash. I changed package and pin configuration to use pins leading out of the package in Quartus 18.1 (Lite).
Now the problem is that I can program the *.sof file to FPGA via JTAG but I am not able to program *.jic file to flash. I'm getting error:
Error (209025): Can't recognize silicon ID for device 1. A device's silicon ID
is different from its JTAG ID. Verify that all cables are securely connected,
select a different device, or check the power on the target system. Make sure
the device pins are connected and configured correctly.
I found that this could be caused by bug which is in version 18.1 till 19.4. I can program the modified project to DE0-Nano so I don't thing that the bug is the problem.
What are requirements to program the project to flash?
  • FakhrulA_altera's avatar
    FakhrulA_altera
    Hi Langail,
    This thread has been marked as inactive and will be transitioned to community support because there is no update received from you in a while.
    If you have a new question, feel free to open a new thread to get support from Intel experts. Otherwise, the community users will continue to help you on this thread.
    If you feel your support experience was less than a 9 or 10, please allow me to correct it before closing or please let me know the cause so that I may improve your future support experience.
    Thank You.
    Fakhrul
    FakhrulA_altera
    Hi Langail,
    I wish to follow up with you about this case. Do you have any further questions on this matter?
    Please feel free to let me know if there is any concern so that we could further assist you.
    Otherwise, this thread will be marked as inactive and will be transitioned to community support because there is no update received from you in a while.
    Thank You.
    Fakhrul
    FakhrulA_altera
    Hi Langail,
    Thank you for reaching out.
    Just to let you know that we have received your support request and I will be working with you on this.
    Allow me some time to look into your issue.
    I shall come back to you with the findings.
    Thank you for your patience.
    Fakhrul
