Cyclone IV E: EP4CE22F17C8 I/O pins misbehaving
- 4 years ago
I found the issue. I was assigning the wrong pins. I was supposed to be driving A12 instead of A11 and L13 instead of L14.
Ok, you say you are using a custom PCB of your own design. Is there just one instance you have built, or do other board(s) exhibit the same problem?
- AWrithingMassOfFlesh4 years ago
I am seeing the problem on multiple boards with the same design from the same batch. We have x-rayed the PCB's and seen that the FPGAs are mounted properly. At this point, we suspect the issue is either with the chips themselves or with the synthesis.
pre-config post-config
Can someone explain what these lines mean in the boundary scan files I uploaded? It looks like Pin L14 is present in the pre-configuration file but absent from the post-configuration file. I want to rule out the possibility that I am using the wrong configuration in Quartus. I'm using Quartus v20.1.1
