AWrithingMassOfFlesh
4 years agoCyclone IV E: EP4CE22F17C8 I/O pins misbehaving
Hi All,
I am developing with the Cyclone IV E: EP4CE22F17C8. I am observing anomalous behavior from two of the I/O pins on the chip.
I have pin A11 configured as a general purpose output, howe...
- 4 years ago
I found the issue. I was assigning the wrong pins. I was supposed to be driving A12 instead of A11 and L13 instead of L14.
4 years agoThese are the pin assignments below. I circled the problematic pins, and also show the pins that are working correctly with the same configurations. The fact that I am applying the same assignments to these pins and getting different behavior it what I don't understand. I also use the same logic and assignments in a separate project for a different Cyclone IV device where it works as expected.
