Cyclone IV E – PLL Power Track Width Recommendation Clarification
6mil is normally for signal trace. Recommended power trace for PLL is 20mil, however it also depends on your how fast you want the PLL to run.
PLL power is only critical for high speed clock. The impact if the power delivery is not good to PLL during transmission, the clock signal will not clean, and maybe take longer time to lock.
regards,
Farabi
- YogeshaDG5 months ago
Hi, thanks for your response.
In our design, the maximum clock frequency is 33 MHz, and the FPGA uses a 1 mm ball‑pitch package. Due to this, we are able to route the PLL net using a 20 mil trace width after the filtering section.
From the filter output up to the FPGA cut‑out, the trace width remains at 20 mil.
Inside the cut‑out, from the cut‑out region to the FPGA ball, the trace width is reduced to 6 mil to meet the package escape routing constraints.Regards,
Yogesh
- Farabi_Altera5 months ago
Answer provided in previous support.
thanks,
Farabi
