Cyclone IV drop in replacement confirmations
- 1 month ago
Hi Brian,
Agree on the long-term point. Bench power-up alone does not prove lifetime stress. The goal is to stay inside the documented connection / reservation rules, not only “it boots today.”
Q: Need more clarification on this: tri-state w/o pull-up or?
A: Yes. On the density where that ball is GPIO:
- In Quartus, reserve that pin specifically as "As inputs that are tri-stated" (no weak pull-up, no bus-hold). In the .pin file that shows up as RESERVED_INPUT.
- On the board, hard-tie it to 2.5 V (same net as VCCA for the density that needs that ball as power). Per AN 592 / unused-pin guidelines: RESERVED_INPUT may be connected to a high or low on the board.
- So, external hard-tie to 2.5 V + FPGA pin = input tri-stated, no pull-up. Not floating tri-state.
The Quartus migration + RESERVED_INPUT (tri-state, no pull-up) + hard-tie to 2.5 V guidance follows Altera’s published migration and unused-pin connection rules. It is the supported way to keep the pinout legal across densities. It is not a guarantee of long-term electrical behavior for a continuous 2.5 V level on a GPIO that sits in a 1.8 V (VCCIO) bank (for example with SSTL-18 / HSTL-18 on that bank). Absolute VI ≤ 3.6 V and a successful board bring-up do not by themselves prove lifetime margin.
Hi Brian,
reading Cyclone IV datasheet strictly, Table 1-15 has also to be observed. It specifies Vinh,max of 2.25 V for 1.8 V banks. Don't no why and how the spec is related to general 3.6 Vin,max in table 1-3 and 1-4. According to device handbook, PCI diode isn't used vor 1.8 V and below I/O standards.
Regards Frank
FvM
Well if you read from top to bottom:
The table for output uses VCCIO and input Max=3.6V ~ha!
If your statement holds, then the output should be a fixed number as well for generalized numbers.
My question is not about GPIO use cases, you might argue but ticket is about drop in replacement not standard signal goes high / low with current-limited driver.
I will prefer Altera staffs to handle my ticket.
Thank you
- FvM3 months ago
Hi Brian,
I apologize for not reading your question thoroughly. I didn't realize that you asked about feeding 2.5 VCCA supply to a 1.8 V GPIO due to migration compatible pin assignment. That should always work. To be sure, you can check the respective assignment in Quartus pinout table.
I checked that Quartus indicates connection of VCCA4 (PIN_L12) to 2.5 V for EP4CE10F17 if you select migration compatibility to CE22, no matter that's in a 1.8 V bank.
Regards Frank
- BrianSune_Froum3 months ago
Contributor
Dear Sir,
Stop it. Please stop your replies with all do respect.
You referred information from the datasheet and corrects me in previous reply and said the input for VCCIO is subjected to the table from 1.8Vccio aka 2.25 Vmax not the front table VIN max.
Stop your replies and free Altera to response.
For community help and more clear message stop your madness immediate!
Deep appreciation!!!
Brian
