14 years agocyclone IV configuration: VCCIO8 connection
I’m currently using an EP4CE6F17I8LN on a PCB in an AS configuration mode (EPCS4 PROM) and I’m experiencing some issues with its configuration (device stays in POR with nSTATUS low). In my circuit im...
14 years ago --- Quote Start --- Holding nConfig low during power up does not make it come high afterwards. --- Quote End --- nCONFIG is supposed to have a pull-up. If you can hold it low using an on-board programmer, or just short it to ground, then power-up, then release nCONFIG, it should go high. Cheers, Dave
