15 years agoCyclone IV assignment for 3xDDR2
I would like to assign the pins for 3 ddr2 components : - fpga = EP4CE30 F484 - DDR2 micron 512mb x16 (MT47H32M16HR-25EG) I choose these pins (http://www.altera.com/literature/dp/cyclone-iv/ep4ce30.xls) : ddr1 = bank3 : dq3b x16 / dm3b x2 / dqs3b - dqs5b / clk - clkn=PLL1_CLKOUTp - PLL1_CLKOUTn ddr2 = bank7 : dq5t x16 / dm3b x2 / dqs0t - dqs2t / clk - clkn=PLL2_CLKOUTp - PLL2_CLKOUTn ddr3 = bank8 : dq3t x16 / dm3t x2 / dqs3t - dqs5t / clk - clkn=PLL3_CLKOUTp - PLL3_CLKOUTn is it right ? - 1 bank is not enought to assign all pins, can I choose any regular IO for other pins (addr, cas, ba, cs, odt, ras, we...) ? in any other banks ? - there is only one couple rup/rdn per fpga side. does each couple can be use for the 2 banks ? thanks1 Reply
"AN 445: Design Guidelines for Implementing DDR and DDR2 SDRAM Interfaces In Cyclone III Devices" table 7 gives me the answer for the pin assignment.
what does "altera recommends" means ? I don't have enough IO per bank to fit an entire ddr. what are the consequences when cas, we, cke... are not in the same bank as dq and dqs ? for rup and rdn i think like stratix devices, cyclone IV use 1 calibration circuit for 2 banks. but no clue for this point.
