12 years agoCyclone IV and Arria V combo
I would like to ask if there is some special stesp to take when connecting de0-nano board to Arria V GX Starter Kit. I must set 3.3 V I/O Standard in Pin Planner. Anything else? My application is simple: SPI master as de0-nano board and SPI slave on Arria V GX board. Thank you!1 Reply
I think you've about covered it. Perhaps more generically, ensure the signals are connected between banks powered from at same voltage on both boards, not necessarily 3.3V, although 3.3V will do fine.
Make sure you also take a ground connection between the boards. Regards, Alex
