12 years agoCyclone IV and Arria V combo
Hello, I would like to ask if there is some special stesp to take when connecting de0-nano board to Arria V GX Starter Kit. I must set 3.3 V I/O Standard in Pin Planner. Anything else? My appli...
12 years agoI think you've about covered it. Perhaps more generically, ensure the signals are connected between banks powered from at same voltage on both boards, not necessarily 3.3V, although 3.3V will do fine.
Make sure you also take a ground connection between the boards. Regards, Alex
