15 years ago
Cyclone III with 5v inputs
I'm trying to connect approximately (16) 5v TTL inputs into a Cyclone III eval board, the terasic de0 [1]. These are all input towards the FPGA only. The eval board has (2) 40-pin IDC headers for the free I/O pins.
I've read something about a first generation Cyclone that using the internal PCI clamps, and an external resistor to bring 5v into the board. I don't believe this will work for the III, but needed advice before I proceed to spend $$$ and time on an alternative solution.
I'm also concerned about AN 447: Interfacing Cyclone III and Cyclone IV Devices with 3.3/3.0/2.5-V LVTTL/LVCMOS I/O Systems. [2] I guess I should worry about the overshoot.
Of course I searched the forums before posting, and did get some valuable information from one recent post. [3] Searching the forum for very short keywords like "5v" and "ttl", or even "5v ttl" doesn't work well.
I was going to create a small custom PCB that sits between the eval board and the inputs. The output towards the FPGA board is a 40-pin IDC connector using a standard old school hard drive cable.
The input to the board will be via a single row of .1 on center male header pins. I'm going to use 6" cables from those pins to a chip clip that will connect to a DIP in another system that is primarily 5v only.
The PCB will have at the center (2) 74LCX245 sold by NKC electronics. [4]. [5].
I was also going to put a ~500ohm resistor in line with the output of the transceiver towards the FPGA with the hopes of both meeting the sample circuit in the 245 datasheet and also for the series termination/minimizing reflection purposes in the 447 application note.
The eval board has VCCIO locked to 3.3v and presents 3.3v on the 40-pin header, which I can use to power VCC on the LCX245.
The signals are at either 7.15mhz or twice that rate, 14.3mhz.
Does this sound reasonable? I'd appreciate any ideas on improving it. This is a one-off prototype design that will probably never leave my basement, but will likely be documented online. This will be my first custom PCB.
Keith
[1] http://www.terasic.com.tw/cgi-bin/page/archive.pl?language=english&no=364
[2] http://www.altera.com/literature/an/an447.pdf
[3] http://www.alteraforum.com/forum/showthread.php?t=30591
[4] http://www.nkcelectronics.com/5v-to-33v-logic-level-shifter-bo.html
[5] http://www.fairchildsemi.com/ds/74/74lcx245.pdf
    Well, the DE0 is intended to be a cheap board, so I guess they lopped those off - sorry for the confusion. I would suggest IDT Quickswitches over the 245 parts, though. Quickswitches have a much lower propagation time, and are inherently bi-directional - which means you don't have to reserve a signal to switch direction. They are essentially an array of FETs operating in the linear region, so they dynamically adjust their resistance with voltage. You do still get an "output enable" if needed (usually used for hot-swapping). The only downside is that they require a fairly odd voltage to operate on, 4.3V (Vccio + 1V); but as it happens, it's easily obtainable with a standard 1N4148 diode and a 10k resistor due to the low current requirements of the part. I've used them on boards in the past, and they really do a fine job. I'm using a few octal parts on a board I'm working on now, but I saw data sheets for a 20-channel part as well.
    --- Quote Start ---
    Might be worth a follow-up email with Terasic to verify - or just check the board for a whole bunch of 3-terminal diodes near the connectors.
    --- Quote End ---
    So I did both.
    --- Quote Start ---
    There is not any protection diodes for the free GPIO pins, so we do not recommend our customer to import the 5v TTL into the board. If you have to, please try to decrease the input voltage to 3.3v to avoid damage the board, thank you!
    --- Quote End ---
    and from visual inspection, there's definitely nothing there.
    Keith
    --- Quote Start ---
    In my opinion, 500 ohm series resistance isn't too high for slow and medium speed signals. Another option for 5 to 3.3V conversion not yet mentioned is a simple resistive divider.
    --- Quote End ---
    I was originally going to do a resistive divider on a solderless board. But then the practicality of it hit me, 16 * 2 = 32. That's a lot of resistors, and when I sat down, it's just a big pain in the butt. I looked for alternative package of resistors, and I didn't find one that would work the way I need it. Also don't know if the resistive dividers would just naturally support the series termination requirement of AN447.
    Using those little boards at NKC (that contain the LCX245) would be more convenient, handle 8 connections at a time, in on one side, out on the other. Most of those solderless boards won't do two sets of ICs SIDE BY SIDE(40-pin on left, say, and the boards on right), which, for wiring purposes is the most ideal.
    I've wanted to do a PCB forever, and this might be a good excuse.
    I'd prefer soldering the connector, the two LCX245 boards, and then even 16 through-hole resistors(for termination) that have consistent lead lengths to cut, and so on. Much cleaner and permanent solution. If I get some PCB schematic capture/layout experience for a more complicated project later, then so be it!
    I'm pretty green with this stuff.
    Keith
    --- Quote Start ---
    it appears they forgot to include the schematic for the protective circuits, but they do mention that they exist.
    --- Quote End ---
    Where do you see this mentioned? My simple conclusions from clamp diodes missing in the schematic is, that they have been omitted. If you have the board, you are easily able toc check, if they are present though.
    --- Quote Start ---
    Usually Terasic puts protective diodes on their boards to make the I/O 5V tolerant. I know my DE2 has them, and I believe the DE1 has them as well. (BAT54S) I looked up the manual for the DE0, and it appears they forgot to include the schematic for the protective circuits, but they do mention that they exist. Might be worth a follow-up email with Terasic to verify - or just check the board for a whole bunch of 3-terminal diodes near the connectors.
    --- Quote End ---
    I'm going to email them to double check, but I don't think they are there.
    I just looked at the board, and there are definitely not a bunch of 3-terminal diodes that I can see. Should there be (1) per pin to protect? aka 72 of them for my board?
    Keith
    --- Quote Start ---
    Your design sounds reasonable.
    Did you notice that NKC sell pre-made boards for $1.95
    However, I believe the DE0 has input protection clamps, so you would not need this circuit. Please review the schematic of the DE0. It should be on the CD available from Terasic.
    Cheers,
    Dave
    --- Quote End ---
    As a matter of fact, this is exactly what I was intending on using. I linked to it originally, but because of forum policy, I couldn't show the links directly. (I posted a way to view the links)
    Of course, I paid $6.00 for them before they were discounted. :)
    I both looked on the schematic and checked the actual board. Looking near the connectors, I don't see a big multiple of anything. There are (72) free pins, so I'm guessing I would need 72 of "something" nearby. I just don't see them?
    Keith
    --- Quote Start ---
    Hi Keith,
    Adding a translator in between the 5V signals and the Cyclone III is a must, you wouldn't want a DC signal at the CIII input pins above 3.6V. For AC transitions you can go over that, but only for very brief periods of time, but still nowhere near 5.0V.
    The 500 ohm series resistor sounds a bit excessive though, usually something more in the range of 25 to 50 ohms does the trick. 500 ohms would likely give more of a saw tooth waveform with slow rising and falling edges, 50 ohms will give much sharper edges and still dampen the reflections.
    --- Quote End ---
    Hi Keith,
