12 years agoCyclone III VCCA current?
I power 4 PLLs of a Cyclone III VCCA with a 50mA LDO regulator. I only use 1 PLL. What current should I supply? 50mA should be fine? I can't find details of the VCCA consumption in the datash...
12 years agoThanks,
the PowerPlay tells me 35mA, so I'm OK I had already set Preset Low in the megawizard, monitoring the power supplies VCCA and VCCD_PLL - I could see no glitches - I tried adding 2 x 100n caps (0402 to the bottom of the BGA!) to no affect I think I have finally solved it with a 22R resistor in series with the 40MHz oscillator. It looks like poor routing of the clock on the PCB. Thanks again for the advice
